RE: Xtreme CRIII Oil Pump Spacer
On the link below you can get the above.
http://www.xtrememotorco.com/accessories/Default.aspx
Which alows you to fit a light weight Kitaco crank, and if used with a takegawa primary gear you can use one of there high capacity oil pumps, has any one done this mod?
What part numbers have you used?
I think it will be an ideal mod for the big cc's.
How can l tell if me engine is the required "C" series engine.
Thanks
