93 xr650l fcr41 problems
heres my problems
1. idle hangs up after reving/gentle blips, then stalls. hard to restart, have to hold the throttle open slightly, then ok until touching the throttle again.
2. random stalling, wont restart for a minute.(probably the same prob as above)
3. the pilot screw seems to do nothing at all. stays running screwed all the way in or out.
it seems to run pretty good otherwise. its new to me so i dont have anything to base it on tho.
the bike
93 xr650l
fmf power bomb header
supertrapp can
675 big bore
foam oem style air filter in airbox
desmoged
new carb mount/boot
and of course the fcr41
the carb
main 170
needle OCEMR
clip 5th from top
slow jet 48
main air 200
pilot scew, not a jet
@ sea level
ive spent hours trying to get this right but i am stuck. any recomendations would be greatly appreciated!!!!!!!!!!!!!!!!!
i've gone from all the way in to full out, in 1/8 turns with almost no change.
the hole on the lower left, looking into the carb, correct? should i ditch the airbox and go to a k&n pod? thank you by the way!
In consistant idle can be lack of slack in the throttle cables. The cable spool on the carb rather than having a round bottom in the spool/pully has a crotch that the cable sticks into if it does not have sufficent slack.
As for the jets, the main sounds large for use with an "E" series (3rd didget) needle.
