ACERBIS Supermotard front fender
:ride: Some where on here I have seen, a fitting guide for the ACERBIS Supermotard front fender i.e hole positions and advice on how to mount it(position etc).
I have gone through the search function but drew a blank :applause:
Can anyone please help ?? :thumbsup:
Many thanks in advance
you should have gotten a template sticker its pretty simple. stick it on the mounting point and drill in the spots it says for the drz.
For my '06 S i used the holes in the reflector bracket as a template. I then promptly threw that sucker away! :thumbsup:
Later...
Cover the holes on the bottom of the triple clamp with a piece of masking tape. Punch out or trace where the holes are, and then transfer the tape to the fender.
:thumbsup:
Drill the holes 6.1 mm.
Front holes are on 56 mm centres.
Rear holes are on 56 mm centres.
Front to rear are on 60 mm centres.
The centre line of the front holes is 4.5 mm forward of the centre
of the sprew [sp] "the mark where the plastic is injected".
Neil. :thumbsup::ride::applause:
