Tranny oil much more dirty after rekluse?
For about 5 rides now my Tranny oil is coming out really dirty. Seems to be related to the time I put the rekluse in. Anyone else have this problem that is running a rekluse? I re-checked and the rekluse is right at .035 spech. I run Honda 80 wt red and change every single ride..no matter how long, short, usually around 40-70 miles. The red oil is grey is "swirly" even after 40 miles. Everything seems fine otherwise. I use the tranny (ie what gear I am in) the same as before the clutch change, so no I am not making it slip a lot by riding too high og a gear etc.
Thanks
i don't have one but the way you describe it i think it just wears alittle more than your stock clutch thus creating dirty oil
It must be the Recluse, as my tranny oil even after 2 hare scrambles still comes out a slight Golden color, and very clean.
THe REcluse may run hotter as it has to slip the clutch plates more, therefore building up friction heat, that will blacken your oil.
Skippy
