1996 XR600R stock suspension recommendations.
I did do a search and could not find this information. So for a Honda Newbie please help.
I just picked up a 1996 Honda XR600R with a stock suspension. I am 5'11" and weigh 170lbs. My riding is mostly light trail and single track and normally skewed with lots of baby head rocks. I am 50ish and enjoy long walks on the - Oh never mind! :ride:
As I got the bike the rear preload was set way soft and the rear compression damping was set at zero clicks. I am not sure how to set the rebound damping on this bike. Weird knob under the shock bottom?
The front forks are set about 1 1/4" above the triple tree and I assume they have no rebound damping. Fork air pressure is set at zero.
I assume that the PO had this set up so it would sit as low as possible. Being vertically challenged myself :thumbsup: I would like to keep it low but have a proper suspension.
I have set up suspensions before but am NO expert at it. Would anyone have the stock, starting positions for this bike?
Fork height above triple tree =
Front compression damping =
Static Sag =
Rider sag =
Rear compression damping =
Rear rebound damping ?? =
Thanks in advance.
Marc
