If a jet is clogged will it still run?
If a main jet is clogged will it still run and just have no power at full throttle? Or will it get no gas at all?
Well mine starts to want to stall after half throttle and i was thinking full throttle is dealing with the main jet so i thought mabey its clogged.
What you think?
Considering it only takes about 3 minutes to check...check it....if its clear, Id pull the carb and see if youve got air filter oil in the Main air Jet in the mouth of the carb...if that is clogged, it goes way fat and will run about the same way...
