stock sprocket (front and rear) size for 04 rm250?
whats the stock size for the front and rear sprockets on an 04 rm250?
I can tell you tomorrow. I can check my manual or count the teeth on the sprockets.
I think the front is a 13(?) not sure about the rear.
cool thnx. i bought the bike used so no manual and i think the previous owner may have changed the sprocket gearing couse my top speed seems a little low.
The tranny has a close ratio. it will top out fast. You will have to gear it up (and loose some slow speed gearing) if you want more top speed. In the desert of WA state I was always in 5th....but I refused to put a tooth larger (14t maybe) and loose the slow put put gear.
My last bike was a 89 Yamaha WR 250 and the tranny was a lot more offroad friendly (hard to run out of gears) but my 04 is a ripper anyways.
Gearing is relative to the terrain you ride and is often a trade off.
Rhino
im not really concerned with getting more top speed just want to know if the previous owner changed the sprockets. i dont like not knowing.
