CR80 fork question
I searched but could not find the exact anwser I was looking for.
What is the fork tube diameter and last year of the CR80 with conventional forks?
1995 forks are 35mm, i think crf150 is the same dia. i dont know what they have inside.
if you do a search here or check on Ebay or a parts site you will see for sure the cutoff year for the disc/no disc forks. Off the top of my head I cant seem to remember what i recently got, but they are about 84-85, drum front that matches perfectly with the stock XR/CRF front wheel and brake. The only thing you will need to do is to shorten the overall length. The triple clamps and bearings work on the XR frame. If you dont shorten the forks then they are too long and kick the front end out and up too much. The longer CR brake cable will be needed also for that.
