Hydraulic Clutch?
Just wondering if a magura hydraulic clutch is worth the $200. I recently used it on a ktm and it was smooth and had a very easy pull. Also the idea of self-adjusting for clutch wear sounds nice. The fact that it doesn't fade sounds nice also. Basically I'm just wondering if anyone has used it and what their thoughts are on it.
id buy it for 200$! if you've used it before it should give you some expirience in installing it and if you say u like the hydraulic then go for it :thumbsup:
They are great, until they fail. If you get one, make sure you take some spare fluid in a syringe to get you out of the poo poo.
The self-adjusting is nice, but a well lubed cable and an ez pull cluthc lever will give you the same results.
