gearing calculator
ok so i found this gearing calculator, http://www.4strokes.com/tech/, (7th article down in middle colum) it basicly tells you what your top speed is and all that stuff.....try it. but anyway i need to know these answers. so does anyone know the following:
[i filled in what i know]
Primary Drive Ratio-
1st Gear Ratio-
2nd Gear Ratio-
3rd Gear Ratio-
4th Gear Ratio-
5th Gear Ratio-
Front Sprocket (Teeth)14
Rear Sprocket (Teeth)51
Chain pitch-
Countershaft to axle dist.-
Shortest possible-
Longest possible-
Wheel Rim Size (Inches)18
Tire Width (MM)
Tire Depth (%)
Engine Minimum RPM-
Engine Maximum RPM-
Maximum Power RPM-
my tire size is 110-100-18, i think 18 is in the right spot, but i dont know where the 110-100 goes.
thanks a lot guys. if anyone has any ?s or is confused please ask
brian
come on guys, nothing??? some one must know some of this stuff. anything can help.
