JD Jetting for WR250F
Hello,
Can't get the jetting properly even with the JDJetting ? Help please !
WR250F 2004
free mod
Twin air filter
GTY insert
Jd Jetting Blue needle with C-Clip at groove 5
Leak jet at 90 (Stock) Tried the 40 and it was worse, have 70 to try !
Main jet 185
rest all stock
The bike still has a little bog at 1/4 trottle. I need a new jetting setup because I just bought a YZF stock pipe.
What should be my new jetting setup ?
Thanks in advance !
Marty
Try-
#40 pilot jet
2 turns out
Red marked needle in #5 from top clip position
#180 main jet
#70 leak jet
Make sure the pump linkage is set to start squirting just after the slide moves upward.
Ride the bike for a few miles before evaluating the jetting, making sure that it is completely hot.
Thanks,
James
Hello,
WR250F 2004
free mod
Twin air filter
GTY insert
Main jet 185
rest all stock
Thanks in advance !
Marty
Run the YZF needle and jets and you will be very close.
