michelin s-12 vs. pirelli mt 83 front tire
I've been running the s-12 front and love it in single track :ride: but we have lots of rocks here and after a number of rides the side lugs start to tear off or chunk. :applause: Anyone know if the mt 83 holds up any better? It's dot approved and I'm not sure if this means it has a stiffer sidewall or stronger lugs or more ply's. Anyone know? The tread pattern seems identical. I have tried the maxxis si , dunlop 756 , pirelli mt44, michelin m-12, But none of these seem to cross over very well to other trails when there is hardpacked greasy clay, and rocks . :thumbsup: Any comments or suggestion are welcomed, thanks.
MT83 is a great tire. My personal favorite on the front. Give one a try, You'll like it.
The reason the MT83 has a dot endorsement is because they spent the $ to have it tested and endorsed. A lot of other tires could get it if the manufacturers wanted to spend the $ to have it rated.
In southern Indiana we have hard clay, rocks and even some sand. When its wet, its greasy on top and when its dry, it gets silty. And I haven't found a better tire than a Dunlop 952. It grips very well and has never chunked out. IMO, its the only tire to have.
thanks for the reply guys. How is the 952 in single track mud?
My experience with Dunlops is they stick OK but wear out fast.
The 952 held up very well on my cr 500. I didnt really notice how the grip was since you dont need it on a 500.
I have a similar problem when I go up north it is 90% sand some really deep and the other 10% is kinda hard pack with rocks in it most are rounded not razor sharp ones
and just about all the tracks around here are sand but I ride in my yard alot and it is hard pack obviously with grass so is the trail behind my house harp pack is the 952 that great or is the 756 a better tire or another brand maybe
I like the 952 more then the 756. The 952 lastes longer too.
Another vote for the Scorpion Pro MT83 ! If it isn't one of your favorite tires it is only because you haven't used one !
Dwight
