Putting S carb back on...
OK...I've done it before when I did my re-jet....BUT...it damn near takes an act of God to put the carb back in after making changes. I know that there has to be a trick/tip from all of you who make re-jetting a habit. What's the trick??? :thumbsup:
Jered
Some suggest disconnecting the subframe - I have and wouldn't again.
If you use some careful brute force (yeah, probably an oxymoron) you can push the airbox boot back a fair way and hold it in place with a rod of some sort. It deforms, but goes back into shape.
Cheers
Yeah it seems that brute force works but scratches the $hit out of my subframe with the intake side of the carb. Damn engineers!
Suzuki designed everything on the engine to NEVER be removed!!!
I remove the upper subframe bolts and rotate it out of the way, it wasn't that bad, and no bleeding digits!
what chickenhauler said. That's what I did, works like a charm
My trick was to twist the carb on its side then insert into the front boot, then get the rear boot lined up and use a screwdriver as a shoe horn.
That worked for me. The subframe is easy to unbolt but a major beeotch to get bolted back up alone.
Why, lift with the right hand and insert the bolt with the left, while standing on the left side of bike.
I do it every time I have ever removed my carb, and I have had a lot of practise :applause::applause:
And tomorrow I shall do it just for fun, no not really, I need to fit my FCR.
On the other hand I may just say, sod it, and go fishing instead.
Neil. :thumbsup::ride::applause:
Can't go wrong fishing.
I think is the actual frame you are scratching, not the subframe - and I have done it too. Still, pushing the boot back gives you more room to twist and turn the carb around the other obstructions.
Cheers
How's that old saying go !!!!!!!
A bad days fishing, is better than a good days working.
I shouldn't have said I was going fishing though, it's now pissing with rain and the wind (easterly) is getting up, so much for summer :ride:
Still as I have to work on the bike outside, I may as well get wet fishing.
Neil.
:thumbsup::applause::applause:
Neil.
You do know they sell fish at the supermarket, right?
I took mine out the first time and never again. I've rejetted 6-8 times w/o removing it from the bike. Works for me YMMV. :thumbsup:
leave the little rubber boot on the carb, align hole on cylinder head approximately, push...carb pops right into place and you dig the boot out with your finger. Am I missing something here?
Cheers
Yep....That's what I meant. "Removing subframe" was still in my head from reading your post. :thumbsup:
Just know you're not alone! I slapped some duct tape on the frame, and used a box end wrench (round end so as not to tear the boot) to lever the rubber air box boot back. Thought about the sub-frame, but with my luck I would tear some wires or such...
It's not for food, it's for sport, and fun.
Neil.
Is that a carp? Yeah, I can't blame you for not eating that if it is.
