HT cap + valve clearances
For the first time since I got bike I was stripping top end to do valves today and as I pulled on the HT cap (to get at plug to remove it) it fell apart !! Can I replace the cap on its own as it would appear that the end of the HT lead is bolted to the cap ?
Also, the clearances on the inlets were spot on but the exhausts came up at between 0.3 and 0.35. Will order shims today but is this clearance anything to worry about ? I would expect it to be tighter than standard ?
Thanks. :thumbsup:
