Boyesen water pump
I have an 04 CRF450 that loses coolant through the drain tube after each ride. When I check the level it is about an inch below the reeds. Now, I live in AZ and run Flatland Racing radiator guards. The cap is fine and I think the seals are ok because it blows out the drain tube. Would a Boyesen water pump reconsiliate the problem?
The Water Pump is onl going to flow more water thru the motor. Do you fill it up every time you lose some? It might be at the right level after it loses a little. Remember when stuff heats up...It expands...
Thanks for your reply. I do fill it up each time and have thought of that. But, after each ride it is an inch or so below the top of the reeds.
