forks bottom with a loud clank
I took my forks to a local motorcycle shop to get the seals replaced and when i got them back i took the bike out and when i landed on the first jump it bottomed out with a loud noise like metal hitting metal. Should i just put more oil in it or what. Thanks in advance
A guy brought me a fork that did that after his dealer did his seals. No oil. None...well..not none..enought to lube the bushings....sorta...but it was honestly about 20cc...and they werent leaking...It was just a harried mistake...but man...its a pretty dog gone big mistake
Did you check the compression clicker setting, maybe it's adjusted all the way out to the softest setting :thumbsup:
a friend of mine had the same problem as he changed the springs. I disassembled the forks and found washers (for more spring preload) that were not centered. the inner tube was hitting that washers one inch before travel stroke ends. it also made a loud noise like metal hitting metal... :thumbsup:
