KLX650C Dead :(
I was on my way to work the other morning when suddenly I noticed a lack of
power. When I pulled in the clutch to change gear the engine would
die (instantly the bike would be quiet), let it out again and it
seemed to be running (and even pulling).
Once I was off the freeway and slowed down, the bike cut out (with the
clutch in) and would not come back at all. I stopped and could smell
gas very strongly. I loked down and noticed a lot of gas had somehow
spewed out of the filler cap and was all over the top of the tank.
I tried to start it again with the electric start, but it was no-go.
The starter seemed to be turning, but sounded different compared to normal.
I pushed it the rest of the way to work (thankfully not up hill),
where I tried to start it again. Apart from an incredibly loud
backfire (glad I was still wearing my helmet), I got nothing.
Right now all 3 of my vehicles are off the road. It's going to be a
very expensive month :thumbsup:
So far I've checked and confirmed that I have fuel and I have a spark.
The starter definately sounds different (like it's doing less work),
but with the plug out I can see the piston going up and down.
I took a couple of pictures, one of the spark plug tip...
http://www.flickr.com/photos/12316837@N00/217461912
and one of the dark spots I can see on the piston...
http://www.flickr.com/photos/12316837@N00/217463425
I also tried a brand new plug after spraying some wd40 in the cylinder and still nothing.
Any ideas what could be wrong?
It's a 1995 'C' model.
Since it didn't make any funny noises and seems ok at speed and has spark I would look at the pilot jet.
Good idea, I'll strip the carb down tonight. (I had been offroading for the first time 2 days before this happened, so a fouled carb is quite possible).
Here's one thing that depressed me last night. Although when I try to bump start it ti does feel like it has compression (or at least that much resistance), I removed the plug and put my hand over the spark plug hole and hit the starter, but I felt nothing at all.
I really hope it's something simple and doesn't need a rebuild.
Any idea how much a rebuild would cost me?
Are you plugging the spark plug hole with your finger or just trying to feel air blowing out?
Sounds like you've already determined you have spark.
They symptoms you have sound very similar to a problem with my KLR600. It turns out that the bolt holding the sproket on the intake cam backed itself out, so the sproket was turning, but not the cam. Take your valve cover off and inspect the cams. turn the starter and make sure both cams are turning
Before you do that you might want to take the carb apart and clean it, also check the air filter, if its really dirty particles might be going into the carb and clogging the jets.
I was pressing my hand over the spark plug hole on top of the head (although it's a long way down to the actual hole).
How do I check my cams are turning? Should I use the starter to do that? With the valve cover off ? Which part is the valve cover, sorry I'm a bit of a newb with bike mechanics.
Okay I got the valve cover off. Someone did a realy sloppy job of the gasket last time. Anyway, the cams seem to turn fine (when I hit the starter), and I can see the valves go up and down. What next?
First thing you need to do is get check your compression with a gauge. Your video sounds like your starter motor is working hard to turn that motor over.
Agree with P_M; you need a properly-timed SPARK; a correct MIXTURE, and adequate COMPRESSION for the engine to run.
You have spark; sihce the engine ran recently, you can assume the air/fuel mixture's not totally off (I'd further assume you're running fresh, "dry" gasoline, your fuel tank/float bowl is NOT contaminated by moisture settling to the bottom of either/both); a compression gauge will inform you of the compression (use a hot battery for the compression test; open the throttle while cranking).
Poor compression may indicate bad rings, bad (sticking and/or eroded faces/seats) valves, or improper valve timing (as in, cam chain slipped some cogs, an unlikely possibility from viewing the video).
If compression's o.k., but the engine still doesn't fire, I'd consider ("DO NOT TRY THIS AT HOME") a whiff or two of ether-based STARTING FLUID (have a fire extinguisher handy; no kidding); the starting fluid will insure a combustible mixture.
Good luck!
I'll pick one up tomorrow.
Make sure you get one with a 10mm adapter. If I remember right the KLX has that. It's either 10 or 12, but I believe 10 as it was a pain in the butt to find a set with the 10mm in it.
I got one with the "universal" rubber plug.
I have no compression :thumbsup:
I called the dealer and spoke to the service guy, and he says as a rule of thumb it costs about $1000 for a rebuild :ride:
That's over half of the value of the bike. Should I try and fix it myself? Or should I get another used bike and strip mine down and ebay the good parts to recoup my losses?
I just recently passed 8000 miles.
Going to tear down the head next and see how much more damage there is.
From the looks of that cam and surfaces, it might just be time to strip anything good off the bike and take it to the junkyard. If you find more damage (as I'm sure you will) it's not gonna be worth fixing. It looks to me like your cam was running without oil. When did you last change your engine oil? An oil passage in the head may be plugged (that caused all this)
Jaffa where in cali do you live? If your in so-cal I could help ya out with the rebuild. I'm replacing the top end on my fo-fiddy and it all looks the same. So if the rest is not that bad of shape you can pick up parts for it on ebay cheap and a new top end. Beer is alot less money than $1000 to fix your bike. Just an offer. :thumbsup:
