kitaco inner rotor kit
what does an inner rotor kit do for the bike? if it makes it go faster then i want one...lol
it didn't do anything for my CRII other than forsing us to make every input become smoother.
no engine breaking.
easy to tune.
no instructions needed unless you are totaly clueless.
maybe if you ride dirt its a good thing but not roadrace.
its the way to go if you have a cam, piston, carb etc.... but on a stock 125 not worth 250$.
better to spend your money on the rear shock
:thumbsup:
Good advice, the shock is pretty good on my bike... might get a cdi thing...
I didn't ask for stupid comments if you would have one or not need instructions on how to install and set timing advance
simply install the kit.
the bike will run how ever it is set.
adjust for advance or retarded ignition.
tune it until it runs how you want it to run.
Make sure you tighten the fastners prior to installing it as once you have put it together its a drag to try and tighten the stand offs with the plate installed! Use lock tight too. You might have to make your own wire connections with splices or quick disconnects, might even have to add some wires for the ground etc..
Its really straight forward :thumbsup:
I installed one about 2 weeks ago.
tested and tuned it for 2 hours.
My son used it for 3 hours in a roadrace school in the rain.
We then raced it for 3 hours non stop that evening.
the next day he practiced with it and then did 3 sprint races.
NEVER 1 problem with it :thumbsup:
you better be a schmoove operator :ride:
