Am I getting took?
I have the 04 Honda CR 250. I just purchased Factory Connections rear linkage because it is suppose to make the rear supension action much better than stock. I removed the stock linkage last night to install the FC linkage and noticed that the FC linkage was the exact same size and shape of the stock. I don't see how it can be an improvement over stock if it is the same dimensions. What is up? Am I missing something? Or do I need to send it back? Russ
Russ,
are you sure it isn't 1 or 2mm different in the center-to-center length than the stock parts?
Those aftermarket links usually don't differ by much and can be difficult to see without close inspection. You could call and ask them what the differences are so you could check for yourself.
And FC's definition of "much better" may be different than yours - and for what application? They may think it's better for SX but it may bite for trail riding.
:thumbsup:
