stalling sucks
I have an 06 "S" that likes to stall when cracking throttle too quickly from idle, if I roll on it seems to be fine.
Motor is bone stock...
Any suggestions?
mine did the same thing, I just turned up the idle a bit and now there is no bog or stall coming hard off of idle. Its possible that the idle mixture screw needs adjusting but I have not put in the extended screw or the DJ kit yet, thats for next week. :thumbsup:
Seems to be normal. Mine has always had an issue if you blipped the throttle at idle with no load on the engine - about half the time it will die immediately. Re-jetting and adjusting idle mixture helped the bike run better under load, but didn't change the tendency to stall if I blip the throttle at a light. I just quit blipping, and have no problem.
