quick shimming help please!!!
ok i dont know if it is me or what but this excel thing is a bit funky....
i have a measured clearance of
R-in, .002/.0508 with shim 175
L-in, .003/.0762 with shim 170
R-exh, .014/.3556 with shim 265
L-exh, .016/.4064 with shim 265
now i input these into this excel program off the sticky here and i get new shim sizes of
R-in, 174.9238
L-in 169.9492
R-exh 265.0756
L-exh 265.1264
.....thats so close to the shims in there now.... all are off by less then a tenth of a shim size....with the hot cam shims i bought go by 5's. 2.60,2.65.2.70,2.75
i mean this is my first shim job am i missing something here? :thumbsup:
thnx all
use crfsonly valve shim calculator. you need to type it in thousanths, not mm example/ .006 and shims also go in thousanths
i have no idea what u talkin about. crfs only is a good one and so is the manual in ur book..u can also do it in your head. you figure how many thousanths of clearance you need to gain and then subtract that amount from the shim thats in there to figure out what shim you need. then just covert back to metric
well when i put in these clearances and the currect shims in there the excel program says but in a shim XXX. which is only .1 MAX off from the current shims i have in there now. like current shim 170. it says use a new shim of like 169.7xx i think it was.*at work atm*
i figure i would try the excel seemed easyer i guess i did something wrong.
so for the equation in the book convert all to standard find new shim size and of course convert back to metric?
Example - R-in, .002/.0508 with shim 175
Your intake clearance should be .006". Here's an easy way to calculate the req'd shim size without fancy spreadsheets.
.006" - .002" = .004" difference.
.004" x 25.4mm (conversion to metric) = .1016mm, we'll call it .10mm
Since we need to loosen the clearance we need to reduce the shim size, in this case .10mm, soooo 1.75mm - .10mm = 1.65mm or a 165.
You should always measure the shims, because a 165 is usually not 1.65mm especially not HotCams shims, which I've seen measure as little as 1.62mm.
One of the best explanations I have seen on here regarding shim sizes!
:thumbsup:
Thanks man!
Here's an even easier way than that.
Use this sheet and count up or down from the shim you have for each .001 you need to change the clearance.
The part #'s are for the 450.
14901-MBB-000 .0472in 1.20mm
14902-MBB-000 .0482in 1.225mm
14903-MBB-000 .0492in 1.25mm
14904-MBB-000 .0502in 1.275mm
14905-MBB-000 .0512in 1.30mm
14906-MBB-000 .0522in 1.325mm
14907-MBB-000 .0531in 1.35mm
14908-MBB-000 .0541in 1.375mm
14909-MBB-000 .0551in 1.40mm
14910-MBB-000 .0561in 1.425mm
14911-MBB-000 .0571in 1.45mm
14912-MBB-000 .0581in 1.475mm
14913-MBB-000 .0591in 1.50mm
14914-MBB-000 .0600in 1.525mm
14915-MBB-000 .0610in 1.55mm
14916-MBB-000 .0620in 1.575mm
14917-MBB-000 .0630in 1.60mm
14918-MBB-000 .0640in 1.625mm
14919-MBB-000 .0650in 1.65mm
14920-MBB-000 .0659in 1.675mm
14921-MBB-000 .0669in 1.70mm
14922-MBB-000 .0679in 1.725mm
14923-MBB-000 .0689in 1.75mm
14924-MBB-000 .0699in 1.775mm
14925-MBB-000 .0709in 1.80mm
14926-MBB-000 .0719in 1.825mm
14927-MBB-000 .0728in 1.85mm
14928-MBB-000 .0738in 1.875mm
14929-MBB-000 .0748in 1.90mm
14930-MBB-000 .0758in 1.925mm
14931-MBB-000 .0768in 1.95mm
14932-MBB-000 .0778in 1.975mm
14933-MBB-000 .0787in 2.00mm
14934-MBB-000 .0797in 2.025mm
14935-MBB-000 .0807in 2.05mm
14936-MBB-000 .0817in 2.075mm
14937-MBB-000 .0827in 2.10mm
14938-MBB-000 .0837in 2.125mm
14939-MBB-000 .0846in 2.15mm
14940-MBB-000 .0856in 2.175mm
14941-MBB-000 .0866in 2.20mm
14942-MBB-000 .0876in 2.225mm
14943-MBB-000 .0886in 2.25mm
14944-MBB-000 .0896in 2.275mm
14945-MBB-000 .0906in 2.30mm
14946-MBB-000 .0915in 2.325mm
14947-MBB-000 .0925in 2.35mm
14948-MBB-000 .0935in 2.375mm
14949-MBB-000 .0945in 2.40mm
14950-MBB-000 .0955in 2.425mm
14951-MBB-000 .0965in 2.45mm
14952-MEB-000 .0974in 2.475mm
14953-MEB-000 .0984in 2.50mm
14954-MEB-000 .0994in 2.525mm
14955-MEB-000 .1004in 2.55mm
14956-MEB-000 .1014in 2.575mm
14957-MEB-000 .1024in 2.60mm
14958-MEB-000 .1033in 2.625mm
14959-MEB-000 .1043in 2.65mm
14960-MEB-000 .1053in 2.675mm
14961-MEB-000 .1063in 2.70mm
14962-MEB-000 .1073in 2.725mm
14963-MEB-000 .1083in 2.75mm
14964-MEB-000 .1093in 2.775mm
14965-MEB-000 .1102in 2.80mm
14966-MEB-000 .1112in 2.825mm
14967-MEB-000 .1122in 2.85mm
14968-MEB-000 .1132in 2.875mm
14969-MEB-000 .1142in 2.90mm
14970-MEB-000 .1152in 2.925mm
14971-MEB-000 .1161in 2.95mm
14972-MEB-000 .1171in 2.975mm
14973-MEB-000 .1181in 3.00mm
These are all the valve shims available for the CRF. The shims are marked in mm but they are rounded to three digits: 1.825mm is acutally 182 on the shim and 1.875mm would be marked 188. As far as the measurements in inches, I carried them out four places. If I would have rounded them, you end up with two different shims with the same english measurement. Must be the shift between the two standards I guess. RR.
the more and more i hear about hot cam shims....they are not sounding that good......sigh..... especially with the sizes. the increments are not that small....is there a shim "kit" that i could buy for example like that table that i don't have to worry about not having a specific size? i know i read a post RHC started. something about the shim , i want to say tolerances to heat? someone said oem was the best there was another brand also in there better then hot cam. any recommendations?
oh thanks so much...i kinda got the idea with the book equation. i just figure i would use this excel... leaves no room for error. but that didn't work*either my end or the excel end*
:thumbsup::ride::applause::applause::applause:
much thanks !!!!!!!
