rear caliper problem
2001 DRZ400E
i'll post some pics and try to explain my problem. I really hoping someone can shed light on my problem :thumbsup:
the picture on paper shows what the microfiche says i should have, the part is what is on my bike
this is the other side of the braket in question
this is the PROBLEM, my pads are only halfway on the disc.
Just a guess, but I think you have an RM or RMZ calliper bracket not a DRZ one.
The RM and RMZ has a larger rear disc, you need either a DRZ carrier on an RM/RMZ disc.
Oh, the DRZ "SM" uses the larger disc as well.
Neil. :thumbsup::ride::applause:
yeah, it's an e-model converted to an SM...
thanks for your reply on the RM/RMZ point...
what is better to do, can i be sure if i get a bigger disc it will fit?
I picked an aftermarket RM disk from Rocky mountain for cheap. It is for my set of dirt rims so wear is not a primary concern
ok, thanks for clearing that up, so all this will lead to a performance upgrade, doesn't that happen more often then not? :thumbsup:
