minor problem
My stator wire pulled away from the crank case last night while i was cleaning my bike. The only reason i knew it happened was i heard a hiss sound as air was comming out of the hole. It has only seperated slightly but i want to seal it back down before it pulls away completely. What would be the best thing to use to re-seal it to the case? :thumbsup: I tried crazy glue but that didn't work for anything, the wire is too stiff and the glue doesn't hold it down.
hmm....epoxy? gorilla glue? just a thought, see if it works..
i tried some epoxy and that didn't work either, i have some sealent/adheasive that i'm going to try now, if nothing else to plug up the gap.
Silicone, it's what they use on it in the first place.
Yup, sometimes after a little trial and error you hit it right. I used some black silicone sealent/adheasive and it seems to be the ticket. I'm going to let it set til this evening and maybe throw another coat in the gap if needed.
