Possibly prob. with float in Carb...not getting gas uphill
I own a 2002 DRZ 400s. I've done my dj rejet according to the specs that Eddie laid out plus the standard 3x3. After doing those things I've noticed that when riding trails I'm not getting steady gas to the motor when climbing hills or jumping. It seems to be cutting out during these times. When the bike is running level I have no problems...it only occurs on inclines.
Could this be a float issue? Thanks for any help you can offer!
Dellis,
Have you disconnected or defeated your kickstand cutoff switch? When jumping, your kickstand will partially pop down and cut your power. Common problem. Not sure about going up inclines though....
Yes i have...it seems like a problem with carburetion. Thanks for the reply!
