will dr 350 wheels fit drz400e ?
If you have machining skills then yes. DR350 has 15mm axles. Or at least i recall so.
I have both bikes, the 1991 and 1994 rims that I have don't fit.
Maybe the newer DR350 front may, I think they changed the hub/axle in 98/99.
Hmmm, So what about other hubs that fit drz?
May be dr may be another brand that I can find used or new hubs cheaper...
Pre 03 KTM's have 20mm axles front & rear. The rear hub fits as is, spacers needed in front.
I am not suggesting to use these in DRZ SM since the rotors are going to be expensive (240mm rear = have to use KTM 950 Adventure rear rotor; 310mm front = Husaberg SM front rotor)
I used an 01 RMZ 250 front hub for the front SM wheel that I am lacing for my S. It worked fine and I picked the whole wheel up off ebay for about $60 which was much cheaper then what I could of got a DRZ wheel for. I used OEM RMZ spacers on the front and it worked great. The 250 RM hub will work also. The only catch is your don't have the speedo gear built in to the hub, but I have a Vapor speedo on my bike so it didn't matter in my case.
A DR350 rear wheel will fit on a DRZ400, the axle is the correct size as is the brake rotor.
rmz250 up until this year was yellow kawasaki.are you sure thats what you used?
if the DRZ rotor fit,it wasnt a RMZ 250 wheel.
I am using the rotor that came with the wheel. I haven't tried the drz rotor on it. I will have to check the next time I have it torn apart.
tntmo,
Which year dr 350 wheel fit on the drz400 S?
There is a guy selling the wheels of a dr 350.
