Question about Jetting Database
Embarrasing :thumbsup: question, but what do they mean by
Model (S, E, or K) ???
I cannot for the life of me figure it out!
I got a new and still stock S model and I'm lokking for doing the 3x3 mod to it but i would like to know if the jets comme in the DynoJet kit and also what would you chose for jets for a average ride from 3000 to 5500ft knowing that the mod will be done on the stock pipe and also the 3x3 air box. Also where can we buy the fuel mixture screw. thanks for your help
jetting kits come with a main jet assortmant and may come with a larger pilot jet depending on the kit. if you go to dynojet they say exactly what comes with it. fuel screw comes from TT store, get the keintech instead of the zip-ty. steel vs. aluminum
here ya go
http://www.dynojet.com/pdf/3109.pdf
http://shop.thumpertalk.com/product_p/int_kientech_drzsfms.htm
get the float bowl screws as well
http://shop.thumpertalk.com/product_p/int_tt_drzbltkt.htm
or if ya just wanna go to the local harware store they are M4 x 0.70 (3) 10mm
and (1) 12mm
start your own thread for jetting advise
before i got my fcr i had the stg 1 DJ kit and ride in ver similar conditions
my setup:
all stock except 3x3
MJ 142.5
PJ 25
dynojet needle on clip 3
tune fuel screw for smooth idle
thaks for the help Sean. That's some good info. I read about the database for the jet and thay were showing MJ134 PJ25 and 4th clip with stock needle. What do you think about that? By the way, what are the stock jet setup un the S model?
the stock needle is much different and runs much richer. therefore needing a smaller main jet. whichever kit and or needle you use will determine your main jet size. stock uses around a 134 while the dj kit uses around a 142.5 while the jd kit uses a larger one yet. the stock needle has only one clip position, so i dont know why they said 4th clip when there isnt a 4th clip on a stock needle.
stock S model jetting
142.5 main
22.5 pilot
stck needle with out adjustments
fixed fuel screw (i think they run em about 1.5 turns out)
also notice that i corrected some info above. i said "M3" bolt size when they are actually "M4"
thanks. I think I will start with the MJ134 PJ25 and stock needle with the 3x3 and stock pipe mod. For the fuel screw, I will have to order the extended one unless the stock can be turned out to 2.5 turn "if needed". How does it sound?
you can turn out the stock one but there is a pressed in brass plug that must be removed. drill a hole, screw a sheet metal screw into it and pull out with pliers. i recommend you get a jetting kit as the needle makes all the difference
