[B]Bike Runs A little hot[/B]
My scoot runs a little hot and I am sure it's a combination of things.
The motor has a hot cam, pro circuit hige compression piston and H/D valve springs, boysen water pump cover & impeller, (I run engine ice) fmf power bomb carbon-4 pipe, jd jet and surge kit and vortex ignition.
I just blew a head gasket, but I think that was due to the summers high pressure radiator cap.
I also have the devol radiator guards but I think I'll go back to the stock set up.
I ride tracks only but most of them are a little tight and I don't let the bike idle.
It runs much hotter then it did stock, I just wanted to see if anyone else experienced the same heat issues with a mild hop-up.
TKS
