goodies for a YZ250f
Here is the plan.
I have projects of buying an old stock YZ250f (03-05) if I can find one somewhere and here is what I plan to add to it.
The goal is to chase friends on the track during the week ends.
Engine
-Hot Cams
-Hinson Clutch
-FMF Header and pipe
Others
- Renthal sprockets and chain
- Works connection clutch perch and lever, glide plate, rad guards, frame guards
- TM Design chain guide/slider
- Pro Taper handlebar
- Acerbis hand guards
- Factory Effex graphics and Seat Cover
Any other goodies I should include in the budjet?
What do you guys think?
Thanks
High compression piston
Thought about it but NAH!
More compression = more heat = less reliability. I don't wanna get into that at all.
Thanks for your suggestion. :thumbsup:
If you want the truth, ditch the fmf and get a white brothers, pro circuit, rocket, or dr. d exhaust.
I want a header/pipe combination that will increase bottom power, not only peak HP. which one is the best?
Amd by the way, what the h... is "Rocket "?
yeah not a big fan of fmf. mostly because they are overgloried. they have good pipes but id go with the dr d. oh and rocket is a semi new brand that has not really been tested alot. looks cool though.
I've seen (heard) the DrDs a lot on the track. they have a great reputation.
I'll consider seriously. White bros and pro circuit are serious stuffs I'm sure...
Get your suspension set-up before you go blowing huge amounts of cash on a 1-3 HP increase with a pipe. Suspension will actually make you faster.
I would just leave the cams stock! For the reliability reason as above. I can not see that much of a gain by changing the cams. They might change the powerband, but that will either add to the bottom end or top end. I have not tried different cams though. Make sure you try the 50 tooth rear sprocket though.
oooook :applause:
all i have to say is that your way off, where did you learn the above/who told you? :ride:
I've got a Rocket Exhaust on my 250F. Check out my garage for a picture or two. I will vouch for what a great pipe it is and for the price you CANNOT beat it. Plus, it looks totally trick, which is always good if you have friends you need to one-up.
oooook :ride:
all i have to say is that your way off, where did you learn the above/who told you? :thumbsup:
I'm not sure to follow you. I can't be way off saying that more compression leads to more heat can I? This is just laws of physics. Then I can't be way off saying that overheat is not really good...
What I mean is that the YZ250f engine revs high enough, has already what? 12.5 comp ratio, low amounts of oil considering the performance and heats way enough as is... I'll buy a 450f before buying a high comp piston...
Just my humble opinion.
Do you guys consider the cooling system of the YZF250 can handle a high comp piston easily?
