DR 350 Forks
I have a 94 DR 350. I've seen people swap in a set of RMX forks. Are the RM forks compatable? What years should I look for. Thanks.
Dave
Your best bet would be to IM a poster Im guessing. Do a search for motard here as Ive seen a couple guys with the mod.
The DR uses 32005 top bearing (25mm/47mm) and a 32006 bottom bearing (30mm/55mm).
You need to find some forks that use the same or simular bearings. That will get you close, but you might have to make a spacer to make the stem the right length.
I have a set of KX500 forks on my DR... I used a KLX250/300 triple clamp, they use the right bearings but the stem is slightly longer - I used an 8mm thick spacer to make it fit. The ones I used are 43mm Kayaba's.
You can also use '01-'03 RM250 forks/triple clamp with a 32906 top bearing and the stock DR bottom bearing. No idea on length.
I have a whole list of bikes that use the right bearings, but this is a start.
If I get the chance, I'll look it up.
The KX500 front end from any year will work.
This is for the DR 250/350 which uses 32005 top (25/47) and 32006 bottom (30/55) bearings. The other bearing mentioned is a 32906 (30/47).
OK, here is a list of some stuff that might work...
First Group - same bearings as DR, no idea on stem length -
'91 KX125 K43U
'94-'96 KLX250 K43U
'97-'04 KLX300 K43U
'91 KX250 K43U
'91-'04 KX500 K43U,K46U
'90 RM250 K41U
Second Group - use DR bottom bearing, 32906 top bearing , no idea on length -
'93-'94,'98-'05 CR125R S43U,K43U,K46U
'92-'94,'97-'05 CR250R S43U,S47U
'04-'04 CRF250R,X
'02-'05 CRF450R
'93-'04 RM125 S45U/S49C/S49U/S47U
'93-'04 RM250 S45U/S49C/K46U/S47U
'93-'98 RMX250 S45U/S46C
CR250R 95-96 K43U/K46U
Third Group - use CR top bearing, DR bottom bearing, no idea on length -
CR125R 90-92 26/47 30/52 S45U/S43U
CR250R 90-91 26/47 30/52 S45U
CR500R 90-91 26/47 30/52 S45U
