CRF50F jetting
Ok all ready searched and i cant still find anything.What jet should i use for a 50 with the baffle out and a uni clamp on airfilter, im at sea level and up what would be good to run.
Thanks
you should not have to change jets at all. perhaps your carb is dirty or you have to play a little with your air screw. bikes from the factory are set to be running around sea level you dont have to wory about that unless you are in the mountains or at least over 4000 ft. if your 50 is stock other than the uni filter you just need to play with it. start out at one turn out and move in 1/8 turn increments out till you get it.
