KX 250 2000 Flywheel Question
How can I tell if my bike has a flywheel weight on it or not? Remove the left side case but I'm not sure exactly what I'm looking for. Any help?
Well there's a simple way to test this without even taking the bike apart, when you ride your bike and the bike hits band, does it hit like a mofo, like most 250's or does it have smooth reasonable manageable power? After that you can answer the question yourself.
Pull the magneto cover and if you see an "extra" plate bolted right to the existing flywheel, then you know you have a weight. My Steahly on my 500 weight is gold in color, and is about 1/4" thick.
