450 Crf Mod To My Drz Fcr
I Did The 450 Crf Mod,TO MY FCR Bike Works Insane Now I Was Going To Do The Taffy Mod But I Wanted To Keep The Rubber Sleeve Intact I Didn't Want Dirt Or Water In My Carb
I'm pretty sure he means using the CRF AP diaphragm. I did the same thing when my stock one died, I've been very happy with the results. It has a long stud/shorter squirt.
Grant
Grant
So, you used an acelerator pump diaphragm from a ?450cc bike? CRF carb in the drz's CRF carb?
Can you be more specific?
Is this mod applicable on the DRZ 06 E model?
I have some WOT acelerator lag on the road I was hoping to fix.
Yep, It Works Great,just Change It To A 450crf Diaphram No Head Aches
Is that a Honda 450CRF?
Any specific year or are they the same?
Get The Long Stud Kit It Fits All Fcrs
So is it an aftermarket kit or an original part for 450CRF?
Original, it will come with a few items like o-rings and such for about $40AUS. I just strolled down to the honda deal and had it in a few days. Was cheaper then just getting the diaphragm by itself from Suzuki.
Grant
this only applys to the fcr-mx.disregard the leak jet stuff.we dont have the leak jet.the rest is valid.i o-ring the linkage and set the timing.works wonders.
http://www.thumpertalk.com/forum/showthread.php?t=343587
Um, now you have me a little confused Eddie.
The FCR-MX is the carb fitted to a CRF450R, not a DRZ400E 06 model, correct?
Can I use the CRF450R AP diaphragm to improve the AP response?
That thread you linked has a great tutorial pdf, but it is a different carb to mine.
AP timing is not adjustable on my bike other than changing springs maybe.
So this mod is or is not for the Slant-body carb?
The Mod Is For The Slant Model With The Rod On The Outside The Kit Is 17.00 Works Great Comes With A Needle To Use Everything But The Needle
Thanks...You wouldn't happen to have the Honda Kit Part number would you?
Honda Number 16021-meb-771 It Comes With Cover And Spring And It All Fit And Preformed Great
I thought the mod referred to taking the FCR off the DRZ and putting it on a CRF450.
