FCR MX questions - sorry I searched and nothing
OK, so I installed my FCR MX this weekend and it is pulling hard but falls on its face under load just from idle and on the top end. Its on my 2005 S and came off a 2005 S so I thought it was jetted correctly. My jetting is below:
- 021-216 FCR Adapter 2 3/8", carb to S airboot
- 021-439 Adapter O-Ring
- 017-262 EMN Needle
- P/N 13111-29F00 OEM Suzuki E Intake Manifold
- P/N 09402-58208 OEM Suzuki Clamp
- P/N 13685-29F00 OEM Suzuki Vacuum Port Nipple
- 200 Main Air Jet
- 160 Main Jet
- 38 Pilot Jet
- 100 Pilot Air Jet
The pilot jet seems to be small but I am not sure if that is really my problem, since it seems like it is getting too much gas at low speed.... I have done the 3x3 (actually its 9 1 inch holes and the snorkel removed) have the powerbomb header and the Q2 muffler.
I know this is like the 10,000th post on this but I can seem to find it. Also, I was going to just order a bunch of jets for it. If anyone knows part numbers for them it would be appreciated.... If not point me in the right direction. The carb came jetted I confirmed they are in there correctly and cleaned all of them up before I installed.
Its killing me since I am so close to this thing being perfect :thumbsup:
Sorry I got it from eBay. It came off another S, elevation was less than 300 feet. He claims....
I am not sure but that sounds right.
What should it be? I am at sea level...
the jetting should be
160 main jet
200 main air jet
emn needle
clip 3
45 pilot jet
100 pilot air jet
2 turns fuel screw
squirt duration should be about 1 second.
Thanks, I guess I will hit the TT store.
How does the squirt duration adjust? Is there a digram of the carb somewhere I can see?
Taffy Mod it is. Can't find any pics so if anyone has any please post.
Thanks.
OK, jets are on there way. Taffy mod sounds easy but I have no idea where to get the litte clips. Will see how it goes and let you know.
Thanks agains.
Thanks again... I am going to try the right jetting first but I bet the taffy mod is in my future...
Maybe I should remove my coolant overflow and put in a turkey baster, while I am at it... :thumbsup:
OK, so I just pulled the carb back out and I know its not a MX type... I ordered a new PJ from TT and it doesn't look anything like the one in there?
I have an FCR pumper? Also the extended fuel screw seems not really fit.
What the hell is this thing....
Oh yea, and to make matters worse, I knocked off the hose from the oil tank (black box) last time, so the test ride covered everything in oil... :thumbsup:
