HighCompression piston and higher sprockets!
Just recently we had to replace the piston, cyclinder, and con-rod, and bearings in it. But anyways we are putting a 12.0:1 piston in it and normaly i had a 13tooth sprocket on it and was thinkin about putting a 14 on. And im wondering if this is gonna put alot more pull, and make the motor ping. ??? :thumbsup::ride::applause::applause:
It'll be fine. Honda went to a taller rear sprocket when they bumped the compression from 03-04 in addition to a lighter flywheel. In addition to those, they also got more aggressive on the lead time in the ignition without any issues.
