burnin grapghics
i just installed a front fender decal and its a little old so the sides dont stick well can i melt them to the plastic, not severly but enuf to make it stick?
Can you lift it up far enough to wipe a booger under it? I've got a cold right now so if you need more snot and/or boogers give me a call and I'll come over and help.
Do you have an Oxyacetylene torch with a cutting tip on it?
That could work.
That could work.
That only works if you soak the fender in a bucket of gasoline to loosen up the dirt that is keeping it from sticking down.
Were you focused with your elbows up, head over the handle bars when you put it on, if not that's why it didn't stick.
Did you maybe put it on upside down, with the sticky side up and the non-sticky side towards the plastic? I've done that a few times, let me tell you it does NOT work. :thumbsup:
Wait til the dirt sticks on the edge of the underneath the part that didn't glue down. It will be as annoying as a wedgie.
When the sticky side is out you lose .0000927364521 seconds off your lap time.
At least that's what I heard.
Yeah but over ten laps that really adds up smartass!
Those edges will actually force the wind to hold the front end down so you track better thru the whoops and thru corners. :thumbsup:
But if you wipe out, you would stick to one of the whoops......That would suck.
Those edges will actually force the wind to hold the front end down so you track better thru the whoops and thru corners. :applause:
I thought you said to keep the front end up in the whoops?!?! I'm so :thumbsup::ride:
