need jet specs for kx250f 290 athena BB
On my '04 I never had to rejet when I went to 290. 2 friends have the Athena 290 on their '06 YZ250's and they never had to rejet either. Are you sure you have to rejet?
I have the same kit. Here is the jetting I came up with for sea level, humid, 85-95 degrees; Stock pilot, stock leak jet, 200 main, JD red needle 5th clip position, fuel screw 2 turns out. Found I may need to go leaner on the pilot 1 size for hare scrambles. Bike seem to stall easliy in the woods. Works great on a moto track. I should note that I also have a Boyesen quick shot as well.
Good Luck
for John407,
What is the elevation where you live? .. I'm at 3450 ft above sea level..
