electrics
took my 125 pit bike out on the weekend and it got soaked from puddles which was unavoidable.it started to missfire and cut out.got it started again and took it home then jet washed the bike.failing to start again i decided to look for the problem,i have now realised it was the electrics as they sat under the seat and got soaked.anyway,i blew them dry with an air compressor then cleaned to contacts with a wire brush just to make sure.the thing i want to know is,having now taped and hid all the conectors up should i have sprayed inside the connectors with any sort of protecting spray to stop corrosion?i dont mind untaping and spraying and taping up again unless its not really needed.any ideas?
