Run it by Burned
I got a FCR off ebay. It came off a 2002 YZ 426 & I'm putting it on my 2000 DRZ 400S. I've opened up the air box, changed to a FMF high flow header.
I was pointed a sticky: FRC conversion the burned way.
Sudco is telling me my carb. is a 21 Series because my pilot jet is 3 cm. long. Do I still use the same jets and needle as in the MX? What size starter jet do you recommend?
Is it OK to use a 38 pilot jet and a pilot air screw (5/8 turn)?
I got a Zip Ty fuel mixture screw from the TT store. How many turns do you recommend?
I'm running the bike at about 1665 Ft.
Thank you
