Rebuild questions
Hello all,
I finally got around to tearing the DRZ down. After 4 and 1/2 years of riding, everything looked pretty good, despite some minor pitting in the nikasil and slight signs of the skirt slapping around. I need a few suggestions though...
Since it needs to be replated anyway, I'm thinking of going oversized. I can't seem to find any +2mm piston sets. Do they exist for the drz? Is there even enough material to go 2 or more mm over? And what is the name of that place in Tennasee or Alabama that replates/bores cylinders quick? I used them on my KDX 2 years ago and that plating job is still perfect.
Next any good valves available for the DRZ? Right intake needs to be ground, maybe any oversized valves out there? I wanna do this right, perhaps even before the season is over.
Thanks for the help! :thumbsup:
JE 94mm is the way to go, I just did it, wow.
Bore and plate by Millennium.
Valves from RHC is the best bet.
Neil. :thumbsup::ride::applause:
Well said,, except Neil forgot the springs from RHC. As long as the cyl can be replated with out a sleeve, stick to the 94mm. If it needs a sleeve,might as well go 95mm. 94mm & 95 mm have a 13.5:1 cr option..the 94.5 does not.
Really, that is not what my 94.5mm piston says????
And yes replace your valves/springs/cotters (keepers), seals etc.
Millenium, yes! Thats the name. I'll be keeping stock compression though in case I ever find an S frame w/title.
Its been awhile since I've shopped for parts online, any good ref's to a store with JE pistons?
???? Of course your right.. it's the 94mm that was not available with the 13.5:1 CR.. My apology's My DRZ friends.....
