suspension settings
I have an 06 250f that I want to get the suspension settings just right. I am 150lbs I ride fairly agressively, I like to ride both trails and tracks so does anyone have a recommended setting for good trail handling and a setting to resist bottoming from jumps. I want the suspension to be supple enough for roots on the trail but to also ramp up to resist bottoming off of jumps and how much sag should I be running.
Yz250f
Forks
Rebound - 10
compression - 16
Shock
Rebound - 9
Compression - 9
H/S Compression - 1 1/2 turns out
Yz250f
Forks
Rebound - 10
compression - 16
Shock
Rebound - 9
Compression - 9
are you referring to clockwise or anti-clockwise from the fully turned in position? And even then, how much do you weigh etc, your clicker positions may not help him at all.
About the sag, from what i have read here, people are liking it between 95mm and a 100mm.
