'06 SMR: upper triple clamp
What is the best way to tighten the upper triple clamp bolt while keeping the turn signal bracket in place? The bracket keeps rotating as I try to tighten it to 18 ft-lbs, causing a small gouge in the aluminum triple clamp as the bracket rotated into it. :thumbsup:
Thanks much!
Dab of grease under head of the bolt. Hold and support bracket. Later George
