fork oil for '73 XL 250 Honda
Hello, being new to this forum, I don't know yet where the best place for this question would be, so I just put it in the overall technical section (suspension) aswell. I'm in need of the correct fork oil amount for a '73 XL 250 Honda. Anyone? Thx
Remove the fork springs, collapse the forks, fill to within 6" from the top with 10w fork oil.
Originaldirt
Hey thanks man, 6" from top, that's what I needed. You see, I replaced the fork seals and it had more water in it than oil :thumbsup:
If there was water or another foreign substance in the forks you may want to clean out the inside. Disassemble, then flush with a solvent, and let dry, or blow out with air.
OIl capacity for drain only is 150cc.
Oil capacity for flushed system is 160cc.
Thanks a lot, guys :thumbsup:
@Mike38: I did all that. I know my way around with these things, but thanks for the advice :ride:
