FCR Needle Question
I'm replacing the needle in my FCR from the stock DXP to the EMN needle and understand that i need to step down my main jet from a 165 to 160 (i'm running a full open RS-3 at sea level).
Could someone (Eddie) explain how this works? I understand that the EMN must be tapered more, but i thought the needle pulled all way out of the main jet so that at full throttle the needle has no effect on what MJ to use? Please explain/educate me (us).
As I understand it, all the fuel that gets to the needle jet, first has to go through the main jet, so to an extent a smaller main jet will lean the needle range as well.
This is why you should re-jet a carb from full throttle downwards.
So,
1/float level, 2/ Main jet. 3/ Needle and clip position. 4/ Pilot Jet. 5/Fuel screw.
Each jet will affect the top end of the jet below it, due to the overlap between jets.
There is a diagram in the Dyno Jet kit that shows this.
The float level will affect all settings.
Neil. :thumbsup::ride::applause:
I see. I will report on the DXP to EMN needle change tomorrow morning. See what kinda difference it makes. Hope I can tell.
How do you know where the float bowl needs to be adjusted too?
The Keihn spec that I have calls for 9 mm for all FCR's.
Bike runs about as good as I think possible now. Noticable difference in power. Pulls harder longer now. With the right jetting and the full RS-3, the bike has pretty impressive grunt. Gonna need cams next! Thanks for all the help TTers and Burned!
