CRF230 Jetting Recommendation?
My wifes 230 takes a long time to warm up, pops on decel and runs hot. I suspect it's jetted too lean. What pilot/main/ needle set up work at 3,000-5,000 feet on a stock bike with the air box opened up?
I'm not to sure about your elevation,if you read the jetting sticky or do a search you'll probably see something close. there is a jet kit for the 230 called power up i believe,go to off- road.com dirt bike project 230 you'll get the part number.thats what i have works good from sea level to at least 3000ft probably more i just tweak the air screw accordingly. but the rule of thumb is two sizes at a time
