sm doing weird things on highway. help!
first off i have an 05 sm full rs-3, 3x3, dj jet kit. i was riding on the highway yesterday for about 35 minutes. the thing sounded like it was about to blow up going like 80-85 which is probably more like 70-75 (closer to the speed limit). but every time i let off the gas a little it sounded like it wanted to stall out... also it started to jerk a little bit if i wasn't ON the throttle. any ideas what this is?
Mine had a surge at low throttle openings which was partially cured by the DJ needle, but only fully addressed by lifting the needle 1 notch (to 3 from the top).
Cheers
Sounds like it is starving for fuel. Mine does some funny stuff when it is about to run out, a couple miles later and I have to switch to reserve.
