Questions about tires for SRZ 400 SM
I hope you guys can help. I am replacing my Dunlop D 208 with a Metzler M-3 150/60 . Should I go with the 120/60 front?? Or stick with the 120/70 size like stock?? Seems to me if I go with the 60 on the rear I should definitely go with the 60 on the front otherwise the front will be slightly higher which I do not want. Now it may not mattter at all, but I want to confirm what is best! Thanks.
I'd just stick with the stock front tire, but for reference...
140/70 = 98mm section height
150/60 = 90mm section height
120/70 = 84mm section height
120/60 = 72mm section height
The tire wont actually be that size, they never are exactly as advertised, this is just theoretical.
YMMV
