Carb & Jetting Question
Do you have to take the carb off to change the jetting, I tried to twist it like you can on a 2 stroke, but part of the frame doesn't allow me to do this, is there any tricks?
Not sure if its a trick or not but if remove the subframe and shock, you can then get to it better from the rear. You will probably have to pull it away from the heads intake boot in order to move it enough.
At least this is how I ended up doing it.
