Which Piston???????
I have a question. which piston is better or which do you guys prefer the pro-x piston or a weisco piston?
here is a link to the weisco one.....i kinda liked it better because it comes with the gaskets and it is higher compression but i wanted to get your guys' input first. is a higher compressing better or worse?
here is the link to the pro-x piston
A number of people have reported broken aftermarket pistons on this board. I've used Wiseco's (big bores) on all three of my KX250F's and the've held up very well. The only negative is that they are heavy and I believe that is because they are forged. I use a lighter OEM flywheel to compensate for that. I am looking for a lighter cast piston that can handle at least six months of abuse...
A few Piston weights.
Forged OE is 141.4 grams
Forged OE replacment Wiseco is 141.3 grams
Forged High Comp Wiseco is 144.0 grams
Forged Heavy Duty high comp Wiseco 144.6, shot peened, skirt coated, brushed dome. None of these R734M07700 have ever broke.
Forged Pro-CIrcuit/JE custom is 175.2 grams. (wow what a boat anchor).
Forged custom Big Bore 81mm MaxPower/RPS KX250F 160.8 grams
Both Athena and Vetrex Big Bores are forgings.
The Je piston 13.5:1 I got wieghts 147 grams STD size and new stronger design part number 243642.
My bad... Thanks for clearing that up. I was comparing the stock piston weight with the big bore Wiseco. I guess since my bore is 10% bigger than stock I should expect that the piston be that much heavier also.
I just checked some of my old pistons:
OEM piston ('06) 77mm = 146gm
Wiseco 79mm = 146gm
Wiseco 81mm = 162gm
The 79mm piston really surprised me. I expected it to be heavier. The 81mm is 11% heavier than 79mm but that is only a 5% increase in displacement. Does anyone out there have an Athena (290) piston they could weigh along with stock to compare these numbers to?
