Can't figure this out
As the title says, i just can't figure out what shim size i need, i'm just gettin so confused :thumbsup:
Anyways my left intake valve clearance is .076mm, and i'm shooting for the .127mm range
the shim that is in my bike now is a 302(3.02mm?)
Now what shim size will i need, i used the shim calculator that NoFearOakley48 gave in his shimming valve thread and it said that i needed a 301.949???
heres the link
http://crfsonly.com/calculators/crf250-valve-shim-calc.php
thanks for your help
Subtract the current clearance from the desired clearance and subtract that from the shim size.
Desired clearance : .127
Actual clearance : .076
.051mm
Current shim size: 3.025mm
- .051
Needed shim 2.515mm
ACTUALLY IF YOU DO THE MATH properly... YOU NEED
A 2.97 shim.. Check you subtraction.
