phillip screws in stator plate
Ok I will give you a tip --
# 1 go to a hardware store and buy some #2 and # 3 screwdriver bits try to find some that are not very pointed on the end and an extension that the bits will slide into also get yourself a 1/4 6 point socket that will fit over the bit make sure you have a ratchet for the socket
#2 find the bit that fits the best in the screws insert the bit and the extension and strike the end of the extension with a hammer being carefull to not hit it too hard and also not to hit anything but the extension
#3 slide the socket and ratchet on the bit and attempt to remove the screw
#4 if screw doesnt budge repeat the striking process
# 5 If available use an impact screw driver instead of the above tools but if your in a pich then the bit and extension will work fine if you do it correctly be carefull and wear a glove on the hand holding the tool being struck the better the bit fits the better your luck
